establishment-criteria
gre tunnel
Configures the GRE tunnel establishment criteria
In a multi-controller RF domain, it is always the master node that establishes the tunnel. The tunnel is created only if the tunnel device is designated as one of the following: vrrp-master, cluster-master, or rf-domain-manager.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
establishment-criteria [always|cluster-master|rf-domain-manager|vrrp-master <1-255>]
Parameters
| establishment-criteria [always| cluster-master| rf-domain-manager|
vrrp-master <1-255>] |
Configures the
GRE tunnel establishment criteria. The options are:
- always – Always
automatically establishes tunnel (default setting). The tunnel device
need not be a cluster master, RF Domain manager, or VRRP master to
establish the GRE tunnel. This is the default setting.
- cluster-master –
Establishes tunnel only if the tunnel device is designated as the
cluster master
- rf-domain-manager –
Establishes tunnel only if the tunnel device is designated as the RF
Domain manager
- vrrp-master <1-255>
– Establishes tunnel only if the tunnel device is designated as the
Virtual Router Redundancy (VRRP) master
- <1-255> –
Configures the VRRP group ID from 1 - 255. A VRRP group enables
the creation of a group of routers as a default gateway for
redundancy. Clients can point to the IP address of the VRRP
virtual router as their default gateway and utilize a different
group member if a master becomes unavailable.
nx9500-6C8809(config-profile testNX9500-gre-tunnel-testGREtunnel)#establishment-
criteria rf-domain-manager
nx9500-6C8809(config-profile testNX9500-gre-tunnel-testGREtunnel)#show context
gre tunnel testGREtunnel
establishment-criteria rf-domain-manager
